Reorder your print steps on touch devices
We’ve made it easier to reorder your print steps when you’re designing from your touch device. On your touch screen, you can now long press and drag your print steps to reorder them.
For premium members: Edit in Group is now available in Early Access
To make it easier to manage artwork that you’ve grouped, we’ve added an easy way to edit object directly. This means that, when you are looking at a grouped piece of art, you can use Edit in Group to make fine adjustments to your work without having to ungroup everything.
To try this out, start by turning on Edit in Group in Early Access. Then, right click or double tap on a grouped element. Select, drag, or delete individual elements in this view. When you’ve reached perfection, click Done to save your changes.
