Moiré Explorer
kimpimmel
Seattle
Joined Sep 12, '17
Since I was a kid I was fascinated by the moiré effect when two overlapping patterns create another pattern / image.
After getting my Glowforge, I had cut out some regular patterns of holes and slots etc, and noticed they would create that same kind of interference pattern when overlapped. So I figured it would be a fun exercise to create a gadget with interchangable discs to explore the moire effect. I call it the Moiré Explorer
The first prototype was a simple C-shaped ring with captured bearings to let one disc turn in front of the other. The discs are transparent acrylic and look really cool when turned.
tumblr_p1f9jsQ4TX1rzx9dqo1_400
It’s also lively when viewed from different angles!
tumblr_p1f8xfVJB01rzx9dqo1_400
The final design is kind of a claw shape that can be displayed 3 different ways
tumblr_p1nqehqbgh1rzx9dqo1_400
The construction is 6 layers of PG wood, with spring-loaded bearings that pull the disc into the gadget and hold it steady relative to the fixed disc on the back
tumblr_p1oifekjLR1rzx9dqo1_400
I’m still learning a lot about how to design moiré patterns, but now that I have this gadget, it’s really easy to cut a new design and play around with combinations :slight_smile:
tumblr_p1nq9uOEEr1rzx9dqo1_400
EDIT:
Parts used for Explorer:
  • One sheet of proofgrade wood
  • 3 small bearings
  • 3 wooden dowels shafts
  • 6 thin plastic washers
  • a small amount of 1/16 thick acrylic (optional to keep disc steady, slide easily)
Explore Acrylic projects.
Owl design with LED backing
Proofgrade Acrylic Slump Bowls
Marvin the Martian Pendant
Fleur de Lis Snowflake Earrings
