Unpack the print bed
Your Glowforge’s moving parts, detachable Print Head, and laser tube are protected with two foam blocks and several important orange and red bits.
Save everything! If you ever need to ship your Glowforge for service, you’ll need all the original parts: boxes, handle locks, foam, and important orange and red bits. Store them safely; replacement packing materials are $249.
Lift your Glowforge’s lid and lower the front door.
Remove the foam blocks, being especially careful with the rear block containing the Print Head. Set aside for now.
Unscrew the red knobs on either side of the Print Bed.
4
Remove the orange clip under the glass tube. Push down and it’ll pop off.
5
Gently push the laser arm back and remove the two orange silicone strips on either side of the Print Bed.
