Install the printer head
4
Carefully remove the printer head from the foam block with one hand. Take care not to pull or twist the silver ribbon cable.
5
With your other hand, lift out the second cardboard insert and set it aside - there’s no need to remove the foam block
6
With the Glowforge logo facing up, place the laser head on the square magnetic dock until you feel the magnets click into place.
7
Remove the two foam blocks at either end of the laser arm. The laser arm should now move freely.
8
Place your hands on the black end caps on either side of the rails (as shown).
9
Align the laser arm by gently pulling both end caps towards you at the same time. Keep going until the arm reaches the front of the printer, then push them both to the back.
