My first attempt at wood marquetry and I'm darn proud of it!
jdhassler
Joined Apr 16, '16
IMG_8711
I wanted to try some wood marquetry with my glowforge so as a test piece I started with this humming bird. I bought a sample pack of veneers on amazon which actually had a great variety for around $25 or $30. I etched the whole humming bird image into some medium maple proofgrade and cut the individual pieces from my veneer pack. I’m really pleased with how it turned out. In this image you can see a ripple in one of the front wing pieces that’s because the pieces aren’t glued yet. I just press fit them into the recess etched into the maple. The fit is perfect!!
IMG_8729
The glowforge made cutting and placing the pieces trivial. The hardest part was designing the cut file. Whenever I take a line drawn bitmap image and convert it to a vector in inkscape I get a gap between my cut pieces that is the thickness of the original hand drawn line.
Take for example this image of a clown fish I got from googling coloring fish.
This one has very thick lines to help illustrate my point. When I convert bitmap image to a path in inkscape then break that path apart I get separate paths that I then colored as seen in the image below.
Even with images that have very thin lines my process still leaves me a gap the thickness of that line and for marquetry I need there to be no gap. Anybody have some tips for quickly getting the result I’m looking for without meticulously tracing the image with the vector tool? I also have access to adobe illustrator if there is an easier way to do it in that program.
Explore Wood projects.
Goldfish
Folding iPhone, Galaxy, iPad Stand
Pre Release: What to do with a stout tree?
Carousel Spinner
