Pre-Release | SKOGSTA
karaelena
Springfield, VA
Joined Oct 2, '15
Supplies : Ikea Cutting board
Op time : 19mins 33sec
Ikea is an incredible place.
Glowforge + Ikea Cutting board = Custom one of a kind art.
The cutting board was pretty thick which meant the tray had to come out. I needed to raise the cutting board a bit so the depth checker routine could detect the board. I used a spool of electrical tape to act as a spacer/stand for the board.
I pre-masked the board and drew some lines so I knew where the center, hole and the corners where. Then sized/placed the vector close to the center.
I used an Anker USB charger to act as a square to make sure both corners were at the same distance then hit ‘print’.
I did do a small test engrave in the corner to make sure I had the power/speeds right. But it seems the density of whatever Ikea used varies threw out the board. Which meant it engraved deeper than I’d like. I guess I’ve been pampered by the Proofgrade.
None the less- It still came out pretty good.
MFNY Signapalooza
Leather and wood business cards
First gift project, shared to get input & also a shadowbox offsets solution
Pre-Release | Happy Pi Day
