Moderat "Reminder" Album Cover Acrylic Inlay
iufer
Joined Dec 28, '19
Completed a two-color inlay design from the cover of Moderat’s Reminder EP.
IMG_1617
Material: 3mm acrylic sourced from Tap Plastics
Dimensions: 23cm x 23cm
Offset Path: 0.0625mm
Total Cut Time: ~12 mins
Notes: Assembled and applied cement prior to removing masking and this ensured a very clean final look with minimal glue seepage. I also cut the outer piece face down (mirrored) so that the two colors would join together very tight. Assembly was pretty hard at this scale because the little shapes around the eyes were very small so it was a bit like playing Operation on hard-mode. The artwork came from this image and I used Illustrator to trace and do all the adjustment and prep work for the cuts. Most of the design time was spent making sure that I was applying the offsets and ordering the cuts properly.
Chose to go with transparent acrylic and I’m very glad I did! Light shining through the piece makes for very strong vibrant colors and emphasizes the highlights.
IMG_1618
By selecting the neon yellow I also get glow under UV for free :slight_smile:
IMG_1616
Give the track a listen on Youtube
Explore Wood or Acrylic projects.
A Bright Idea Revisited
Mouse Mirror
BMX Bike Sculpture
More acrylic fun shapes/charms
