Small layered hexagonal twist box
evansd2
Joined Sep 18, '17
Hello, I’m Mike.
IMG_2374
I wanted to try another variation of the approach I used in the layered hexagonal dice box, but on a smaller scale, to test how well the method worked at small scales. Well, the answer is “this good”. I don’t have a great deal of notes on this that weren’t covered in the larger build, this was largely a refinement of the technique.
  • Overall height 1.25"
  • Diameter 1.9"-ish
  • All solid hardwoods
  • Sanded to 600 grit
  • Finished with wipe on polyurethane
Regular readers will recognize the snowflake as coming from my [recent generator post](https://community.glowforge.com/t/simple-snowflake-generator/47563) . The end result turned out pretty nicely at this scale, the woods are inlaid with a 0.007" kerf adjustment. This is aggressive, but I wanted a really close fit.
IMG_2374
Walnut, Maple
A closer look at the inlaid lid. Gotta love the clean corners update, it allows this sort of thing with no overburn hotspots.
IMG_2375
Walnut, Maple
This is another variant on my knurled layered box, and it has a notched lid insert. The notches serve to reduce the amount of surface area in contact with the inside lip, letting the lid spin more freely. This is a concept that I refined again and probably reached its peaked with a rounded, lobed version in the spiral staircase box. I used three pins here for simplicity, more pins are more effort (and again reduced to two pins in the spiral staircase box).
IMG_2376
Walnut, Maple, Brass pins, Neodymium magnets
Oh right, I’m no banamateur here. I refined my sanding technique and did the bulk of the work with a dremel, it went quickly and easily. If I were to do it again, I would avoid sharp internal angles on the sides, it was a tricky task to get them properly sanded.
IMG_2378
Walnut, Maple, Brass pins, Neodymium magnets, US Quarter for scale
So, there you go. We’ll see if I revisit spiral boxes again soon, I have a few more ideas but it’s just a question of whether or not I find time for them.
Oh and bonus points if you can figure out why this one’s named Mike.
Explore Wood projects.
Craftsman-inspired hummingbird window hanging
A different spiral bowl
Namaste Y'all
Just a Quickie (butterfly pitcher coaster)
