Label Rack V2.0
henryhbk
Boston MA
Joined Oct 21, '15
A while ago I got asked by my wife to make a replacement rack for their chart labels at the animal hospital. Well today since I was working from home since I’m on overnight call, she texted me that the old rack was too small, and she needed a new one. She wanted it to be 24" wide. (the old one was 8").
Here is the original
My first reaction was well, I guess I’ll have to buy a monster laser cutter on my wife’s orders! (I mean I don’t want to disappoint her!). So, I explained that the Glowforge is not 24" wide so would 18" wide suffice? I mean the label spools are only about 1/2" wide. Of course being a parametric design in OnShape it was just a quick click on the width variable, change it to 18" and export. It’s in thick clear acrylic. I use copper pipe as the rods since it’s easy to cut metal and copper is bactericidal.
The little holes in the outer plates are for shoving a pin through if the pipe is cut just a smidge too short. It turns out the pipe length is really twitchy with a mm +/- making the difference between easy to insert and falling out.
IMG_2322
(probably should have cleaned off the counter before taking the photo?)
Shut your Barn Door!
Lazy-ness Abounds
Pre-Release | Autoharp Dressup
Keyboard
