LED Acrylic Table Number
victaonline
Los Angeles, CA
Joined Jun 2, '16
Another project forged!!!
I got asked if I could make some table numbers for an event, so here they are.
00100dPORTRAIT_00100_BURST20180909232234906_COVER
I used Clear Acrylic PG and went with the standard GF PG pews/zooms. To connect the floating number to the rest of the acrylic, I used a beaded chain like those found on nail clippers. I could later use something with a little more class, like a silver ring. As for the base, I used the following Touch LED base since I needed something that could be battery powered. I really loved this base since it changes to several colors and has an option to cycle between all of the colors all with the touch of your finger!
IMG_20180909_231522
IMG_20180909_231525
IMG_20180909_231527
IMG_20180909_231532
:grinning::+1:
Update:
I found a similar base that is readily available in Prime for those who can’t wait weeks without it.
Pre Release: A couple little projects
Q-Tip Tub
Proofgrade "New Material" First Encounter
Slide sorter
