Toast Tongs
paulw
vermont
Joined Dec 8, '15
I’ve only been wanting to do this for six months or so, but it became urgent when we replaced our toaster oven. Hook on the end for pulling out the tray stolen from @Jules much prettier design. Living hinge (sorta works) so that you can open the tongs up for a thicker piece of toast. Made in thick draftboard, will be replaced with thick pg ply when it fails. Drawn in inkscape using the living hinge extension (conveniently, you can make a nonce rectangle to put your hinge cuts on, and then ungroup so that you can pick up the cuts alone to put on something that isn’t a rectangle) Engraved circle is for a 10mm magnet and needed multiple passes. Don’t remove from bed till you get the depth right.
svg: tong.svg.zip (1.7 KB)
tong
Explore Wood projects.
EVA's big debut - Harry Potter coasters and a cutting board
Inlaid tissue box cover
Beaver - Stat
Foxy Coasters
