First gift project, shared to get input & also a shadowbox offsets solution
quixotequest
Utah
Joined Oct 1, '16
Since having my Glowforge for a couple of weeks, I’ve found it very helpful for many “honey-dos” for making patterns and props for my wife’s upcoming Lion King theatrical performance. (Thanks for the abundant community ideas here for helping us successfully cut fabric, EVA foams, and corrugate.)
Here’s my first weekend for a from-scratch enjoyment project as a gift for our friends who just lost her puppy this week (who we regularly puppy sit and was our chihuahua’s daddy).
I wanted to ask a question about Proofgrade engraving, as well as share my idea.
IMG_4674
Proofgrade engrave tuning question
I ran some sample tests on draft board and then did the final burn on PG Medium Maple Ply. I found that the engrave (SD) went darker and deeper than expected, so wiping up soot made the color a little uneven—though I still am happy. It was just unexpected after the draft tests. I designed this as a vector in Illustrator, and spec’d it at 100% black. Should I choose a lower percentage of black were I to want to get this a little lighter colored and not quite so deep? (It came out about 0.040".)
IMG_4673
And here’s my idea for precisely fitting offsets for the shadowbox contents to fit snugly together
In case the idea is helpful to anyone else I’m sharing what I created for offsets to make the shadowbox depth layering hold the first maple matte up against the wood holding it away from the front glass while keeping the second matte held against the back where, upon opening, it is easy for our friend to add a picture of her beloved Bug. The second linen paper matte is cut to rest atop a PG Draft Board backing, that received the platform pins, also of Draft Board. With kerf adjustments for the pins and the platform pieces everything fit together snug enough that glue was not needed—just a light tap from a small rubber mallet.
Such a joy to have such convenient precision at hand!
IMG_4675
Engraving Black Granite tile
For you Civil War buffs
Sapele Mahogany and acrylic plaques
My First GF Project
