Bathymetric Map of La Jolla Shores (20x Layers)
ajvince
San Diego, CA
Joined Aug 19, '17
I have a family friend who works at Scripps Institution of Oceanography and he had 2 different bathymetric maps of La Jolla Shores (one from the 1960s). I made 2D and 3D versions. 3D version was a lot of work to trace the image, make the layers and then cut it out.
(Feature Idea/Request: be able to create a workflow that lets you set up a bunch of layers in advance, so you can just stand at the laser, load materials, hit print, remove, load material, hit print,repeat…)
This was my rough draft/proof of concept, I plan to use nicer wood and make a box for it:
IMG_1717
IMG_1707
IMG_1708
IMG_1709
IMG_1710
A different kind of topography
Laser-cut nautical chart of the Lynn Canal near Haines, Alaska
Coasters with local map engravings
Big Data and Small Details
